I know this topic has been talked about a lot as I've done a fair amount of research on this topic trying to fix my CPU's clock speeds but bare with me. I have a Ryzen 5 2600x with an Asrock b450m pro4 and I have done no overlocking with my CPU or RAM. I'm using a 120MM AIO and temps never go higher than 70 when benchmarking/gaming and around 40-50 at idle. During idle, CPU usage will stay around 5-7% but clock speeds will stay at 4.1 GHz and spike downwards (some cores spike more frequently than others) to around 2.7 GHz to 2.0 GHz. CPU usage looks and seems normal to me. I've ran Cinebench R20.060 and performance seems on par with other 2600x. (score: 2836) I have also ran the latest version of Userbenchmark and the performance is also indifferent to the average 2600x. I'm fairly certain this isn't too healthy for my CPU to have the clock speeds running at maximum and spiking downwards the way it is. I will provide screenshots of MSI Afterburner, Ryzen Master and a full parts list.
Here are some trouble shooting options I have tried:
- Changing power settings in windows to Balanced, High performance, and Ultimate performance.
- Using Ryzen Master and using default profile 1, default game mode, and default creator mode.
- Running Malwarebytes which found zero viruses.
https://pcpartpicker.com/list/zHr7rr
https://linustechtips.com/topic/1403550-cpu-always-at-maximum-clock-speed/
Edit:
Sorry, somehow I totally missed that you already tried what I suggested. My bad OP
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
Just now, teedrr said:
I tried every performance plan and There is no discernable change.
Sorry, I somehow missed the part where you already said you had tried this.
GAMER
Home LAB
Racing SIM
Lmao your cpu will not give a flying sht about that and it will not degrade either, only time you should be worried of degradation is if you are running more than 1.6v cpu vcore so unless the 4.1ghz is somehow running at 1.6v or above theres nothing to worry about here
All you are gonna do is nuke performance for nothing, so unless you wanna save your power bills then absolutely no reason to "fix" the cpu clockspeeds, heck id rather reccomend ocing instead since 2600x might be able to gain some performance from oc, only limit here would be 90c cause i doubt youll need any more than 1.6v (assume cpu deathzone ~2v)
Did you download chipset drivers from asrock and try the Ryzen Balanced power plan? Not the Windows balanced one.
Have you ever updated your BIOS?
Also remember that monitoring can cause CPU to boost, Ryzen Master is the most accurate monitoring app for Ryzen. Download from amd.com and have look there.
did you try turning it off and on again?
no, but I think that's pretty normal, my i7-8700 can't overclock, but it's usually at ~4.3GHz at all times, even with nothing stressful open, I think it's just how CPUs are
temps and performance looks to be the same, and you know the saying
if it's not broken, don't try to fix it
