Device is a OrangePi Zero. It runs the latest version of armbian and their own kernel as I didnt want to bother compiling mainline kernel myself and also risk having to set everything up again.
I got two USB3.0 HDDs connected to internal USB2.0 headers of the OrangePi Zero, they worked just fine when they were mounted as their own separate mounts but I needed to put them in a logical volume so that I could fix the messy file structure of my shares. I managed to set LVM just fine, drives are fully operational, however under very specific circumstances this results in a behavior I didnt encounter before.
Issue arises when I am downloading relatively big torrents to the said LVM volume. I havent managed to pinpoint an exact size BUT anything bigger than 3-4g per file seem to cause LVM volume to be unresponsive and server to have a "ghost" load on it. This load does not appear to be any of the user or system processes. I changed USB ports, I even surface checked the discs and they are all fine. All I can think of is this being some sort of kernel issue.
Any command related to the LVM will result in device to become unresponsive, dmesg doesnt have any messages and when device is powered off manually, the next boot takes around 40-50 minutes and after that (usually takes 3-4minutes from cold to all my docker containers to being ready), it boots fine and files are all there.
Any ideas? How do I go about analyzing this issue? Mind you this device is is located in a very peculiar location and physical access is not that easy.
https://linustechtips.com/topic/1403307-issues-with-lvm-and-kernel/
29 minutes ago, Levent said:
3-4g per file
This makes me wonder if it's a 32-bit addressing issue somewhere in the process.
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
I suspect this has something to do with USB. Try disabling USB autosuspend. Do you only get this issue with torrents or do you also get it with any file transfer of about that size?
sudo chmod -R 000 /*
Only on when transmission-daemon is writing to LVM volume. I just copied 40G file to the volume via samba just fine. This device uses uboot, any ideas on how I would go about doing that with uboot? I also think this might be cache related, as I noticed this happens at longer intervals when transmission-dameon is in turtle mode.
I have no clue, there doesn't seem to be much documentation on setting kernel boot flags for uboot.
