2 hours ago, GloriousGamer321 said:
what specs would you need to run minecraft at 200 fps, 16 chunks, graphics fancy, smooth lighting max, smooth lighting level 100%, light shaders, at 1440p 144hz, while recording/streaming, with music in the background, and in a discord voice call?
What version are we talking about here? Obviously modern versions like 1.18.1 are far harder to run than old versions like 1.8.9
either way, if you're planning on building a new PC, this should be easily capable of running that on either version
PCPartPicker Part List
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor  ($186.33 @ Newegg)
Motherboard: Asus PRIME Z690-P D4 ATX LGA1700 Motherboard  ($219.99 @ ASUS)
Memory: Neo Forza FAYE 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($49.99 @ Newegg Sellers)
Storage: Western Digital Blue SN550 500 GB M.2-2280 NVME Solid State Drive  ($42.99 @ Western Digital)
Storage: Western Digital Blue 2 TB 3.5" 5400RPM Internal Hard Drive  ($44.99 @ Adorama)
Video Card: MSI Radeon RX 6600 8 GB ARMOR V1 Video Card  ($479.98 @ Newegg)
Power Supply: BitFenix Whisper M 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($59.90 @ Amazon)
Total: $1084.17
Generated by PCPartPicker 2022-01-07 02:11 EST-0500
Edited by Kilrah
removed orphaned quote
https://linustechtips.com/topic/1401921-pc-specs-for-minecraft/#findComment-15193398
I also highly recommend using Sodium and Iris Shaders, you might be able to get away with a lower tier GPU since these mods in my experience make quite a difference.
Although in this market, this is relatively reasonable.
https://linustechtips.com/topic/1401921-pc-specs-for-minecraft/#findComment-15193414
for latest version there is simply no replacement, though you should note that there are about 30 fabric mods you should have installed, here's all the ones I recommend using
1.18.1 Mods.zip
https://linustechtips.com/topic/1401921-pc-specs-for-minecraft/#findComment-15194405
I'm guessing you're talking about Java? Bedrock will run 16 chunks on an overclocked toaster... last time I played, I was running 72 chunks - it wasn't 200fps, but it was still very playable and useful to find End Cities for my son.... and he runs ~30 chunks on his GTX1050Ti and gets smoother gameplay than his XBox.
Main rig: Ryzen 7 7800X3D, RTX3080Ti FE, 32Gb Teamgroup Create-T DDR5-6000C30, AC Freezer3 280mm AIO, Asrock Steel Legend X670E, M.2 2Tb Samsung 990 Pro, M.2 1Tb WDSN550, SATA 8Tb WD80EFAX, Corsair HX850, LianLi O11 Air Mini + 3x NF-A14's, MSI MPG 271QRX (27"/1440P/360Hz), Gigabyte M27Q (27"/1440P/170Hz), Asus PA248 (24"/1200P/60Hz), G815 kbd, G Pro X Superlight 2, Audezee Maxwell.
Games room "TV rig": 5800X3D, AC Freezer2 280mm AIO, ASUS Prime B450M, RTX4080S w/iChill AIO, 32Gb TridentZ DDR4-3600C14, M.2 500Gb & 1Tb WDSN550, 8Tb WD80EFAX, BeQuiet Straight 1000W,  LianLi O11 Air Mini, LG G4 (55"/4K/120Hz), G815 kbd, G502 mouse, LG G1 Soundbar / Audezee Maxwell.
Lounge HTPC: Minisforum UM760 Slim, Ryzen 5 7640HS, 16Gb DDR5, 1Tb M.2, LG C2 (42"/4K/120Hz), Logitech Touch K400.
Laptop: LOQ16, RTX4060, 16Gb DDR5, 2x 2Tb SN990 M.2.
NAS: Synology 1812+, 3Gb RAM, 3x16Tb Seagate EXOS RAID5, 1Tb MX500 cache, 3x3Tb WDRED RAID6, 120Gb SSD cache.
https://linustechtips.com/topic/1401921-pc-specs-for-minecraft/#findComment-15194445
yes java
https://linustechtips.com/topic/1401921-pc-specs-for-minecraft/#findComment-15194528
13 hours ago, GloriousGamer321 said:
yes java
Cool - I'll step away leave you to the Java specialists 🙂
I've seen Java and I get that there are a few redstone things that behave a bit better and there are some trade-offs with features (sweeping edge vs trident killer machines, etc), but provided you stay away from those awful Microsoft "Realms" and host your own dedicated server, then Bedrock seemed to be the logical choice - not that I really had any choice as my kids were playing on Xbox + Android tablets/TV boxes, so we needed something cross-platform that I could setup on my main PC and then just leave running on an 3rd gen i7 HTPC that seemed to cope pretty well with 4-8 players, 12 chunk tick distance, 72 chunk view distance.
On the plus side, I'm guessing it brings some of the AMD cards into contention as you don't have to worry about ray tracing and the availability + prices on those are slightly less crazy than the nVidia ones.... but these things are all relative as they're all pretty crazy right now 😄
Good luck with your build!
https://linustechtips.com/topic/1401921-pc-specs-for-minecraft/#findComment-15195194
