Using an separated PSU for gpu
Solved by LIGISTX,
6 hours ago, Imbroke2021 said:just wondering if it really safe tho because some forum from toms hardware say using dual PSU aren't safe
It’s safe if you do it correctly, but in your situation with a proprietary power connector it will be very hard to get the PSU’s to turn on at the same time which is required.
But someone said above they found a converter from normal ATX to your dell power plug. I’d get that adapter so you can just use a single ATX power supply. That is your best bet.
