Hey guys. I am searching to buy new or a refurbished gaming laptop for about 1000 euros. I was thinking something like ASUS TUF Gaming F15 FX506HM - Ordenador Gaming de 15.6" Full HD 144Hz (Intel Core i5-11400H, 16GB RAM, 512GB SSD, GeForce RTX 3060 6GB. Or Asus ROG Strix G531GW-AL137 i7-9750H/16GB/512SSD M2/RTX 2070/15.6/FHD 120Hz. So can u guys recommend me something?
https://linustechtips.com/topic/1400641-i-need-help-choosing/
The tuf has big quality issues and is just a bad laptop. Spec wise fine but it's just kinda garbage. The rog is a much higher quality unit but it gets HOT and battery life is poorer.
Any lenov legion 5 with a ryzen 5000 cpu and 3060 available?
https://linustechtips.com/topic/1400641-i-need-help-choosing/#findComment-15184628
A Lenovo legion with similar specs is 400 euros more. Unless I find it at discount somewhere...
https://linustechtips.com/topic/1400641-i-need-help-choosing/#findComment-15185310
Also a Gigabyte G5 KC-5ES1130SH Intel Core i5-10500H/16GB/512GB SSD/RTX 3060/15.6" would be an option to consider.
https://linustechtips.com/topic/1400641-i-need-help-choosing/#findComment-15186041
