1 hour ago, Seb18381 said:
I just installed my new pc and it worked fine for a bit, then while downloading games with the monitors turned off the fans started getting loud and ever since i havent had any signal to the monitors and the cpu debug led had turned on
Possible case heat issue, possible bad mobo, possible bad cpu, possible bad bios, the list goes on..  what are the specs of this machine? Need make and model for every component.  In particular, the case, the motherboard, the cpu, and the bios version in the motherboard.  One never knows what might be indicative of something though. Betsy to have everything.  If it’s a pre-built that stuff can usually be derived from the make/model of the OEM prebuilt itself so if it’s one of those that is likely all that would be needed.
https://linustechtips.com/topic/1398764-cpu-debug-led-on/#findComment-15172748
AMD Ryzen 9 5900X CPU
GIGABYTE AORUS NVMe Gen4 SSD - 2TB
NZXT Kraken X63 Black - cpu water cooling
Corsair RM850x (2021) PSU
G.Skill TridentZ Neo DDR4-3600 C16 DC (AMD) - 32GB
MSI MAG X570S TORPEDO MAX Motherboard - AMD X570 - AM
and a rtx 3080 gpu
i built the pc myself and i worked for a bit and then it stopped worked without me changing anything
https://linustechtips.com/topic/1398764-cpu-debug-led-on/#findComment-15172764
and a rtx 3080 gpu
Case isn’t listed which leaves case heat as possible. AIO should be big enough to move cpu heat if it’s correctly attached.  AIOs are not known for good motherboard air so you might have a motherboard heat issue.  Bios version may also be a thing. PSU is probably big enough for the video card.
https://linustechtips.com/topic/1398764-cpu-debug-led-on/#findComment-15172769
Case is NZXT H510 Elite
https://linustechtips.com/topic/1398764-cpu-debug-led-on/#findComment-15172801
A case famous for heat problems.  The front air is too impinged.  A thing a lot of people do is remove the glass from the front panel.  Apparently it hinges down and removes easily.  If removing it fixes your problem it’s a hot case issue. Did you flash the most current bios? Could be the one it shipped with which almost certainly will need to be updated.
https://linustechtips.com/topic/1398764-cpu-debug-led-on/#findComment-15173065
