Hey everyone happy holidays
Turned off my pc last night like normal and this morning it won't start .. the lights on the motherboard are on but I press the power button and nothing happens
I tried :
- removing the rams and putting them back in
- removing the cmos battery and put it back in
- changing the power outlet
- jump starting the pc from the motherboard with a scew driver.
But unfortunatlly nothing seemed to work
Pls help
My specs are
Mother board : Asus Prime B350-Plus
GPU Asus Geforce GTX 1050 Ti
CPU : AMD Ryzen 5 1600
PSU : Corsair VS 450, 450 WATT
RAM : Corsair Vengeance LPX 2×8GB 3000MHz
https://linustechtips.com/topic/1398643-pc-not-starting/
On 12/25/2021 at 7:07 PM, r0b0f0r0ce said:
What else can I try ??
Your Motherboard seems to be DOA (DeadOnArrival) return or RMA it
Ryzen 9 5950X Gigabyte Aorus Elite B550 V2  MSI RX 6750XT Corsair HX1200 3xLL120 Fans 7xA12x25 Fans 5000D Airflow Vengeance RGB PRO 1.450 @ 4133MHz CPU Cooler: NH-U12A
https://linustechtips.com/topic/1398643-pc-not-starting/#findComment-15183300
