So after months of my pc that wont turn on it finally turned on this Christmas day, but it came with issues now it wont go in POST. Now ive tried to do the basic troubleshooting but still it wont post im afraid that a technician wont come until after Christmas so what are the possible things that i can do to make the pc POST?
MY PC SPECS ARE
RYZEN 3 3100
GIGABYTE B450M DS3H
T-FORCE DARK ZA 3200MHZ
GTX 1660 SUPER
https://linustechtips.com/topic/1398521-my-pc-wont-post/
MY PC SPECS ARE
RYZEN 3 3100
GIGABYTE B450M DS3H
GTX 1660 SUPER
Is there anything that you have done to cause this?
Main:
  • CPU
    10700k 5ghz All core 47 ring ratio 1.275v
  • Motherboard
    MSI Z590 A Pro
  • RAM
    4x8 viper steel samsung bdie: 4200-17-17-30
  • GPU
    Gigabyte RTX 3080 Gaming Oc
  • Case
    O11 air mini
  • Storage
    970 Evo Plus 500gb OS, Sn550 1tb, 860 evo 500gb, 2tb MX500
  • PSU
    RM750x (2018)
  • Display(s)
    Acer Nitro vg272up, Kogan 24 1080 120hz
  • Cooling
    arctic 280aio, EK M.2 NVMe Heatsink on 970 evo plus
    Second:
    Cpu: i5-8400
    Cooling: ID-Cooling Frostflow 120x
    Ram: 2x8gb 2666 c16 hyperx fury, tuned the absolute balls out of it but def not stehble.
    Mobo: Asus Prime H310M-K
    Gpu: Igpu
    Case: Coolermaster MB311L
https://linustechtips.com/topic/1398521-my-pc-wont-post/#findComment-15171349
MY PC SPECS ARE
RYZEN 3 3100
GIGABYTE B450M DS3H
GTX 1660 SUPER
Ok, a few easy possibilities to test:
  1. If you haven't already, remove the CMOS battery (with the system unplugged from the wall), count to ten, then put it back in and reset.
  2. Reseat your RAM. Simple as that. Just take it out, make sure the contacts and clean and there's no debris in the slots, then plug it back in.
  3. Open up BIOS and make sure all of your RAM is reading, then boot into MemTest86+ and let it sit and run for at least 24 hours. If there are issues with your RAM, they'll show up here. If that still doesn't do it, pull out your RAM and try booting with one stick at a time, going across the board from the furthest slot from the CPU to the closest to it, and running that test with both sticks. If MemTest86+ does throw errors, figure out which stick it is causing the problem and RMA it.
  4. Check the connections to your boot drive, SATA and power cables. If you have a way of testing the PSU, either by plugging it into a different PC or plugging a different PSU into yours, give that a shot as well.
  5. Take out your CPU and check to see if there are any bent or broken pins.
  6. Reinstall your OS from a fresh USB installer. You are going to have to wipe your boot drive if you do this, so unless you have a backup, save it for a last resort. Or, alternatively, install Windows onto a different drive and see if that posts. If it does, you can access your old boot drive and get your files off of it.
Just a few ideas of common places to start.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/1398521-my-pc-wont-post/#findComment-15171363
