Seeking switch box recommendation
I want to find a switch box where I can use the same keyboard and mouse on my main computer and my laptop. I would like also to use my main computer monitor as secondary monitor on my laptop at the same time. Do you have any suggestion for me (brand model)? Thanks!
https://linustechtips.com/topic/1395699-seeking-switch-box-recommendation/
You're looking for what's commonly called a KVM switch. Be aware, there's two different concepts that are called KVM - you want the physical switch 🙂
Now, be aware that a KVM switch will allow you to switch your peripherals between computers - not use them on both at the same time.
If you want to use KB/Mouse at the same time as if it was one computer, you'll want a software solution.
