Ryzen 7 5700G with upgrade path
Ajcoolgame
Go to solution Solved by Jonathan Lee,
I think you might want to get a better cooler. Something like the Scythe Fuma 2 or Noctua NHD15 would be good choices.
A case with better airflow would be a good idea if you plan to put a high powered GPU in it in the future.
I'd also recommend going with an NVME with a dram cache. Also, consider going 1TB because they are faster and have better endurance. Here are some options:
Storage: Team MP34 1 TB M.2-2280 NVME Solid State Drive  ($99.99 @ Amazon)
Storage: Mushkin Pilot-E 1 TB M.2-2280 NVME Solid State Drive  ($109.99 @ Amazon)
Storage: Silicon Power P34A80 1 TB M.2-2280 NVME Solid State Drive  ($94.99 @ Amazon)
Storage: PNY CS2130 1 TB M.2-2280 NVME Solid State Drive  ($109.99 @ Amazon)
Storage: ADATA XPG GAMMIX S7 1 TB M.2-2280 NVME Solid State Drive  ($94.99 @ Amazon)
Budget : $1000
Country: USA
Games, programs or workloads that it will be used for: Fusion 360,AAA titles at low 1080p
Other details I’m trying to make a pc with good upgrade path (3070),that also can be overclocked.
This my first build and I think my parts are not equally balanced besides for the ram.
My build has
Ryzen 7 5700G
Cooler Master Hyper 212 EVO V2
MSI MAG X570 TOMAHAWK WIFI ATX AM4
Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3600
NZXT H510 ATX Mid Tower Case
Cooler Master MWE GOLD V2 750 W 80+ Gold Certified Fully Modular ATX Power Supply
Pcpartpicker link: https://pcpartpicker.com/list/qvkZnL
