Front Io trouble
Go to solution Solved by SweatyName,
2 hours ago, whispous said:
Right, ignore your front IO for now. Ignore it. Plug in ONLY THE POWER BUTTON cables into the correct two pins and work on getting the pc to turn on.
I got it to turn on, thanks for all your help
2 minutes ago, SweatyName said:
Front io
I'm sorry, you need to do a drastically better job of explaining the issue.
If you were a doctor and I came to you and said "trouble with my foot" and then told you nothing else, you'd send me out calling me a fool.
https://linustechtips.com/topic/1395246-front-io-trouble/#findComment-15151068
Mb, I am struggling to get the correct order of front io. I keep the motherboard manual for the order and it didn’t work. I watch a few video on it still didn’t work. I am at a lost on what to do.
https://linustechtips.com/topic/1395246-front-io-trouble/#findComment-15151075
Do the power and HDD lights work?
https://linustechtips.com/topic/1395246-front-io-trouble/#findComment-15151078
37 minutes ago, SweatyName said:
No it doesn’t. I have check if my power supply is on.
https://linustechtips.com/topic/1395246-front-io-trouble/#findComment-15151141
Excellent - this is the right starting point. Now connect the power LED cables, and turn it on again. Be certain according to the manual they're the right way round and on the right pins.
https://linustechtips.com/topic/1395246-front-io-trouble/#findComment-15151350
