Help pick pls
Go to solution Solved by outtykid,
Corsair iCUE H100i Elite Capellix Liquid CPU Cooler https://www.amazon.com/dp/B08G1NSG7F/ref=cm_sw_r_apan_glt_fabc_7860J3RZTGGC3F2XA7PJ?_encoding=UTF8&psc=1
Where are you shopping / located? Budget?
What features are you looking for in a cooler and why are you looking at that cooler in particular?
https://linustechtips.com/topic/1394824-help-pick-pls/#findComment-15148737
