Hello everyone I recently upgraded my GPU and am noticing the performance is worse. I'm playing on 2560x1080P and using Vsync 60FPS. However I notice I get dips to 30fps randomly.
Current setup:
Ryzen 2700X
EVGA 750W GQ
ASUS X470-F Strix
FlareX 3200MHZ 16GB
Red Devil Ultimate 6900XT
https://linustechtips.com/topic/1393792-6900xt-low-performance/
So with Vsync on, if your GPU can't maintain 60fps it'll drop to 30 so that explains that. Disable Vsync, problem solved.
As for why you're not able to maintain 60fps, are you playing highly CPU bound games? That's a relatively low resolution for a 6900xt which is going to leave the older 2700x having to keep that GPU fed. This can lead to a potentially unpleasant experience in game.
Can you monitor CPU / GPU usage, temp and clockspeed over time (graphs) while in games? That would likely be the quickest method for determining what's going on for sure. I like HWinfo for this but MSI Afterburner also does this quite well.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1393792-6900xt-low-performance/#findComment-15140535
Are you missing a PCIE power cable???
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
https://linustechtips.com/topic/1393792-6900xt-low-performance/#findComment-15140548
Oh my. It didn't dawn on me to inspect that picture further but uh.. Yeah.
https://linustechtips.com/topic/1393792-6900xt-low-performance/#findComment-15140570
Maybe the GPU is freaking out by the missing power cable
GAMER
Home LAB
Racing SIM
https://linustechtips.com/topic/1393792-6900xt-low-performance/#findComment-15140595
No worries.  That picture was taken during the build process 🤣 I have 3 separate psu cables feeding it.
As for games I mainly notice it in PUBG. Frequent stutters and dips below 60. Occasionally happens in Cold War too
https://linustechtips.com/topic/1393792-6900xt-low-performance/#findComment-15140600
Just now, Mac070 said:
I did use DDU. I came from a 1080TI. Used it to uninstall my Nvidia driver and then proceeded to reboot and install the Radeon software.
 Just to re-iterate...
We'd likely immediately see the issue.
https://linustechtips.com/topic/1393792-6900xt-low-performance/#findComment-15140624
Upgraded from the 2700X to the 5800X. FPS is more steady! Also noticed using vsync at 60FPS 1080P makes the card perform worse since it's not maxing out.
https://linustechtips.com/topic/1393792-6900xt-low-performance/#findComment-15146237
picie power cable is missing.  not recommended at all.  you need to use 3 *seperate* pcie power cables.
yeah because its a 4k card, totally unsuitable for 1080p 🙍‍♀️
but on the bright side, being completely underutilized may prevent it from burning up since you're still missing at least one pcie power cable 🔥
-Scott Manley, 2021
https://linustechtips.com/topic/1393792-6900xt-low-performance/#findComment-15146401
