My laptop wouldn’t charge so I took it apart, and the laptop will charge around 70% of the time when it’s just the motherboard removed from the case, but it will never charge when I put the motherboard and battery back inside the laptop case. The 30% failure rate outside the case and always inside the case, I’m fairly certain is because of a power shortage. Any suggestions?
https://linustechtips.com/topic/1391970-laptop-power-issues/
Is the battery puffy? That can be very bad.
https://linustechtips.com/topic/1391970-laptop-power-issues/#findComment-15127419
