GPU running too hot and best ways to cool it.
Solved by ZePat,
Having 90-100% GPU utilization in GPU demanding games is fine, that's exactly what you want it to do. As for temps, 75C might seem high, but that is perfectly fine. As @FakeKGB mentioned, had it been 95C constantly, that would indicate a thermal issue in terms of airflow. You can always attempt to drop it a few degrees, by adding more fans(provided the case allows for it). But yeah, nothing to be worried about.
