usb drive How to make a 16gb usb drive read as 4gb or less
Solved by BlueChinchillaEatingDorito,
23 minutes ago, CyanideDaydreams said:How do i make a 16gb drive read as a 4gb drive?
Delete all partitions on the drive and make only a 4GB partition. Be warned doing so will make whatever data you have on the drive already inaccessible and may become unrecoverable once you start writing data onto the drive again.
If you're in Windows, you can easily do this in Disk Management.
