Dark Rock Pro 4 fans
SeeSound
so I think one of the fans is broken and it's middle one 135 mm, I just wanted to buy another without everything removing and sending back but they have only 2 versions of 140mm and 120, or 140 also will fit?
The fans use 120mm mounting holes so rounded 135 / 140mm's should work.
Have you contacted Be Quiet! to see what's required for a replacement? If the fan isn't working, you might as well remove it since it would obstruct airflow.
