Hi guys, I have ASUS ROG 553VE NVIDIA GeForce GTX 1050Ti 4GB graphics Intel Core i7-7700HQ 16GB DDR4 128GB SSD + 1TB 5400RPM HDD I have some problems with FPS, my laptop is giving low fps, when I play Warzone, I tried to change in-game settings to very low - low 1080p-720p nothing is changing still getting 40fps , I updated my every driver, I launched and optimized Warzone with Nvidia Geforce Experience but nothing is changing anyone can help me please i will be really glad, NOTE: my friends who has same laptop getting more +10 or +20 fps on some games as he said.
https://linustechtips.com/topic/1390331-1050ti-mobile-low-fps/
Overheating?
You and your friend should compare temps and clockspeeds.
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
https://linustechtips.com/topic/1390331-1050ti-mobile-low-fps/#findComment-15115838
2 minutes ago, BetteBalterZen said:
Overheating?
Unfortunately I had doubt that my CPU or GPU overheating but I used to be sure I analyzed while gaming there is no overheating problem but to be more sure can you recomend me program that we can see results while I play Warzone ( Warzone's GPU display says that my GPU during gameplay is 75-74C...
https://linustechtips.com/topic/1390331-1050ti-mobile-low-fps/#findComment-15115843
Msi Afterburner would tell you specific gpu temps.
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
https://linustechtips.com/topic/1390331-1050ti-mobile-low-fps/#findComment-15115847
Thank you man for help but you know I am not good at pc things can you give me more details that atfer downloading and installing it which process i need to do and what i need to show you guys ?
https://linustechtips.com/topic/1390331-1050ti-mobile-low-fps/#findComment-15115855
hit google and youtube for instructions on how to use MSI Afterburner.
https://linustechtips.com/topic/1390331-1050ti-mobile-low-fps/#findComment-15115873
Play for a while on warzone with MSI afterburner in  the background and after 10-20 min and then check temps.
compare to friends
System Specs
Peripherals
<Razer Mini>
https://linustechtips.com/topic/1390331-1050ti-mobile-low-fps/#findComment-15115877
compare to friends
I am just getting same fps and overlock is not helping there is something that it makes me stuck as same fps 30-40fps max while in insurgency sandstorm i got 50-60fps without problems and i am starting with graphics>high performance.  Please guys help me ! I dont have money to buy new laptop XD
https://linustechtips.com/topic/1390331-1050ti-mobile-low-fps/#findComment-15116571
