5 minutes ago, Schnoz said:
If you have experience working with glass, then you can give it a shot. Though, I'd strongly recommend reaching out to the case manufacturer and asking for a replacement if your case is under warranty, or purchasing a replacement panel from them.
I second this
though i also wanna add that if you dont have experience with glass and cant have the manufacturer replace the glass then you can prob use acrylic instead of glass so much cheaper and much easier to work with + not being able to explode at random
Or be like me and  just make a mesh sidepanel out of mosquito mesh and attatch it with small magnets xD  prob cheaper than acrylic but those sharp edges are quite a detterent
