Samsung 980 vs 980 Pro drive mixup
Solved by BondiBlue,
You got the wrong drive. The drive you got is a worse model. And no, the serial numbers should not be different. You need to return that and get the proper product you paid for, because the 980 is a different product from the 980 Pro.
frozensun ·
Posted in Cases and Mods6 -
2
king0 ·
Posted in CPUs, Motherboards, and Memory2 -
2
5
1
Darkclone ·
Posted in Linux, macOS and Everything Not-Windows0 -
