Help with a second thought!
8 minutes ago, kyrios01 said:but the www.userbenchmark.com said something like my ram is not compatible
userbullshit strikes again.
your ram will be fine, though it will be limiting, id suggest a upgrade on it.
9 minutes ago, kyrios01 said:And finaly... I am asuming that this MOBO Gigabyte Z590 Gaming X have the TPM2.0 for windows 11, but I'm not entirely sure since I haven't found any document that can prove it.
it will have intel PTT. which is a firmware bassed TPM2.0
9 minutes ago, kyrios01 said:Also, the list of Storage compatibility only shows the Samsung 980 nvme Pro, but I cant find the 980 nvme (non pro) anywhere in the list, soo I'm a little concern since m.2 can be tricky when compatibility speaking sometimes.
itll be fine.
id get a 12600k, if your getting a new board and going fo rintel. It should be faster, plys there are DDR4 boards so you can use your old ram.
That 11700k is a waste of sand tm and can push like 300w under load, the i5 will draw less power
