I am currently saving up for my next computer build. It's been about 5 years since my last one and I am getting tired of upgrading so now I am going to save for a ground up build.
Here is the list from pcpartpicker:
PCPartPicker part list: http://pcpartpicker.com/p/3qdm5
Price breakdown by merchant: http://pcpartpicker.com/p/3qdm5/by_merchant/
Benchmarks: http://pcpartpicker.com/p/3qdm5/benchmarks/
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($209.99 @ Amazon)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($107.99 @ Best Buy)
Motherboard: Asus Maximus VI Extreme ATX LGA1150 Motherboard  ($369.99 @ Micro Center)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory  ($139.98 @ OutletPC)
Storage: Asus ROG 240GB PCI-E Solid State Disk  ($314.99 @ Newegg)
Storage: Seagate Constellation ES.3 1TB 3.5" 7200RPM Internal Hard Drive  ($94.88 @ Amazon)
Video Card: Asus GeForce GTX 780 3GB Video Card (2-Way SLI)  ($699.99 @ NCIX US)
Case: Phanteks Enthoo Series Primo Aluminum ATX Full Tower Case  ($219.99 @ Newegg)
Power Supply: SeaSonic Platinum 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($239.98 @ SuperBiiz)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($99.98 @ OutletPC)
Case Fan: Corsair Air Series AF120 Quiet Edition (2-Pack) 39.9 CFM 120mm  Fans  ($24.15 @ NCIX US)
Keyboard: Razer Blackwidow Ultimate 2013 Wired Gaming Keyboard  ($135.99 @ SuperBiiz)
Mouse: Razer Naga 2012 Wired Laser Mouse  ($77.98 @ SuperBiiz)
Headphones: Razer Kraken 7.1 Channel Headset  ($99.99 @ Amazon)
Total: $3535.86
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-04-11 22:21 EDT-0400)
As you can see the price is a little high and things will definitely change before I have all that spare cash, but a lot of the parts are extra like the dual GPUs. I hope to have a new build by years end.
Let me know what you think and any and all constructive input is welcome. Thanks!
EDIT* And the video card I really want is the ROG Poseidon-GTX780-P-3GD5, but it wasn't on PCPP.
"Do not pray for and easy life, pray for the strength to endure a difficult one."
"A place where everything and nothing exists, this is my playground."
https://linustechtips.com/topic/138726-my-next-build/
if you have the money, go for it
i wouldnt get the razer krakens i heard they hurt your ears after an extended period of use
i would get something like this http://www.amazon.com/Beyerdynamic-770-PRO-250-ohms/dp/B0006NL5SM and a clip on mi
get gentle typhoon or noctua case fans, everyone flames the corsair fans for being to loud >.> but they are still good if you dont want to change
hellooooooooo
https://linustechtips.com/topic/138726-my-next-build/#findComment-1849254
budget and uses?
quote me if you want me to get back to you
Specs
https://linustechtips.com/topic/138726-my-next-build/#findComment-1849256
Total: $3535.86
You are overspending in a lot of areas.  With your budget, you should be doing Ultra4k.  Let me show you a very nice $3500 build that is Ultra 4k capable.
PCPartPicker part list: http://pcpartpicker.com/p/3qhkK
Price breakdown by merchant: http://pcpartpicker.com/p/3qhkK/by_merchant/
Benchmarks: http://pcpartpicker.com/p/3qhkK/benchmarks/
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($189.99 @ Micro Center)
Motherboard: ASRock Fatal1ty Z87 Killer ATX LGA1150 Motherboard  ($99.99 @ Newegg)
Memory: G.Skill Sniper Series 16GB (2 x 8GB) DDR3-1866 Memory  ($149.99 @ Newegg)
Storage: PNY Optima 240GB 2.5" Solid State Disk  ($89.99 @ Newegg)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($89.99 @ Newegg)
Video Card: Asus GeForce GTX 780 Ti 3GB Video Card (2-Way SLI)  ($687.27 @ Amazon)
Case: NZXT Phantom 530 (White) ATX Full Tower Case  ($104.99 @ Newegg)
Power Supply: Corsair RM 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($144.99 @ Amazon)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.99 @ NCIX US)
Monitor: Dell UP2414Q 60Hz 23.8" Monitor  ($1067.24 @ Newegg)
Total: $3494.69
(Generated by PCPartPicker 2014-04-12 00:49 EDT-0400)
You could go either SLI GTX 780 Tis, or you could get the brand new ATI R9 295X2.  It is $1500, but is is a single card, and is already water cooled.  Its temperatures are nothing short of incredible for such a powerful card.
Here is a very good benchmark that compares the highest end graphics cards available for Ultra 4k gaming.
If you don't plan on doing Ultra 4k, you are well past the point of diminishing returns in terms of performance.  Going from 1080p to Ultra 4k is where you are going to see the most difference.  SLI 780s on a 1080p screen is going to look the same as me on my 1080p with a single 780.  Go Ultra4k and blow yourself away with the next gen technology.  You have the means to make it happen.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/138726-my-next-build/#findComment-1850007
