So first of all, the issue Im experiencing is that all my networks lose internet access because the default gateway changes to 192.168.88.2 (not 192.168.88.1).
The correct gateway would be 192.168.88.1 - Mikrotik LHG LTE6 antenna. Instead it changes to my second, upstairs AP, which gets internet access from eth1 - the first AP.
Any way to prevent this? I'm new to this
https://linustechtips.com/topic/1386949-default-gateway-changes-to-wrong-adress/
More data is needed. What OS are the machines running? Are192.168.88.1 and 192.168.88.2 wired of Wifi? Why the need for 2 gateways in the first place?
It would be useful if you could do a network map so we can see how your network is setup.
Main Rig:-
Server:-
They are wired, 192.168.88.2 is tecnically a LTE modem i had hanging around so Im using it as a AP.
Heres how my network looks like?
Don't use a router as an access point unless you can disable DHCP as it causes this problem.
2 minutes ago, Airpewdiepie said:
So, I can disable DHCP. Will it continue to work normally?
You should have DHCP off for 192.168.88.1 and on for 192.168.88.2. Then you need to configure .88.2 with a static IP connection to 88.1. Finally all your devices should then connect to 88.2 which will give them an IP via DHCP.
Main Rig:-
Server:-
Okay, I will try that later on, but what would be the result of disabling DHCP server for 88.2?
