3d modelling setup - a small issue
11 minutes ago, omunegru22 said:Thanks man. I will do more research and come back with more details
Something like this should work, and should be well balanced:
The big question mark is the GPU. Here is Belgium you can get a 3060Ti for about 650 EUR, which should fit into your budget. That should be a decent GPU for your needs I think. Shop around a bit for GPUs. A 3060 (non Ti) or similar from last gen 2070 or 2080 (or even 2060) should be fine.
CPU: AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor (2691.89RON @ PC Garage)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler (475.31RON @ PC Garage)
Motherboard: ASRock B550M Pro4 Micro ATX AM4 Motherboard (533.32RON @ PC Garage)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory (881.89RON @ PC Garage)
Storage: Crucial P2 1 TB M.2-2280 NVME Solid State Drive (637.86RON @ PC Garage)
Video Card: Gigabyte GeForce RTX 3060 Ti 8 GB GAMING OC Video Card (3200.00RON)
Case: be quiet! Pure Base 500 ATX Mid Tower Case (357.55RON @ PC Garage)
Power Supply: Super Flower Legion GX Pro 650 W 80+ Gold Certified Semi-modular ATX Power Supply (431.40RON @ PC Garage)
Total: 9209.22RON
Generated by PCPartPicker 2021-10-28 15:50 EEST+0300
