Settings for microstutters
Solved by Omie,
48 minutes ago, RONOTHAN## said:Those settings are fine. Everything but the BIOS settings are what I do every time I install Windows. That said, I could be wrong, but I thought those BIOS settings improve performance if you leave them on, so it's worth experimenting with them to see what performance difference you have with them on and off.
Ah so those BIOS settings actually throttle the CPU to downclock itself and it's supposed to only take effect when not playing games but it can get messy sometimes. With those settings disabled, the CPU will always run at max speeds.
