Muffinator
https://linustechtips.com/topic/138286-entry-level-audio-set-up/
The amp is okay, but it only outputs 10-15w per channel. It wont be pushing the speakers to their full potential but it will still do well. I have the same amp powering 2 6" subs in a custom box I made.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/138286-entry-level-audio-set-up/#findComment-1837186
It's advertised at 30w per channel
Muffinator
https://linustechtips.com/topic/138286-entry-level-audio-set-up/#findComment-1837206
It doesn't matter, there have been tests done and they don't put out near the wattage they advertise. Just go through some of the comments, it was something I knew before buying one.
https://linustechtips.com/topic/138286-entry-level-audio-set-up/#findComment-1837252
I believe it is because of the supplied cord. It out puts 12v at 2amps which is 24 Watts. But I ordered a new cord that outputs 12v at 5amps. It matches up right at 60 watts.
Muffinator
https://linustechtips.com/topic/138286-entry-level-audio-set-up/#findComment-1837255
That's very possible, I didn't bother testing anything out. The subs I bought are cheap and they have a rattling sound when pushed past 70%. I believe it's either because they are low profile subs or because of my box I built. Either way they would overpower the speakers if it was any higher. The subs are rated at 600w peak, 250w rms. So I'm leading to the conclusion my box isn't allowing enough air out for the both of them. But good luck and hope the cord helps them out. :D
https://linustechtips.com/topic/138286-entry-level-audio-set-up/#findComment-1837276
Thanks. Opinions on the speakers?
Muffinator
https://linustechtips.com/topic/138286-entry-level-audio-set-up/#findComment-1837314
They look okay, after having my custom 5.1 surround sound I have more a preference to surround now. But for many years I gamed with bookshelf speakers. When you can separate the channels of audio to different speakers it will inherently sound better. For the price they don't look too bad though. :D
https://linustechtips.com/topic/138286-entry-level-audio-set-up/#findComment-1837344
I used the lepai variant of the amp, it worked well for what I needed.
minor channel imbalance at low volume, but it's a $20 amp what do you expect?
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/138286-entry-level-audio-set-up/#findComment-1840211
