Hi, I'm searching for a ready-to-use NAS box. I have one system I want to back-up to two identical NAS boxes in two different locations as a data loss would be fatal.
The amount of Data I want to back up is under 100GB, so nothing terrible.
If there is a go to NAS to buy preferably with swappable drives anyone here can recommend would be awesome. Thx
https://linustechtips.com/topic/1381955-nas-box-recommendation/
So cheap to implement. Personally for 2nd location at that size i would just go for a subscription of Google One, but you can do both location with the more basic DS220 series from Synology.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1381955-nas-box-recommendation/#findComment-15052755
for such low amounts of data i would not bother with buying two NAS systems and setting them up.
if you want the data in a safe place just upload it to something like Backblaze B2 its gonna cost you only a few bucks a month so its gonna be like 10 years before you would ever break even on buying two NAS systems.
https://linustechtips.com/topic/1381955-nas-box-recommendation/#findComment-15055852
For that sort of data just go down the route of getting some Synology hardware. The price tag may look a bit high for what they are but it's software is easy to use and it'll be perfect for what you need. I started off using Synology NAS enclosures before I got into doing my own servers.
https://linustechtips.com/topic/1381955-nas-box-recommendation/#findComment-15056011
A Synology unit would do the job perfectly. Grab a dual drive one, set it up with mirrored drives.
The Synology systems have an app called Cloud Sync. You setup a folder/share on the NAS and it will automatically sync it with cloud storage.
https://www.synology.com/en-au/dsm/feature/cloud_sync
Supports a decent range of file hosting providers.
Then you'll have redundant drives locally backing up your data as well as your offsite backup covered.
https://linustechtips.com/topic/1381955-nas-box-recommendation/#findComment-15059838
