no post fan spin
My pc fans spin and I think the cpu fans are slowly ramping up til they it their max speed, but them the PC doesn't display anything before just turning itself off
The motherboard light debugg gets suck on BOOT if I clear cmos but if I turn it off and try boot again it doesn't turn on. My pc has:
msi b550 a pro
Ryzen 5 5600x
Coolermaster ml240L rgb
msi gaming x rx580 8gb
16gb corsair vengance 3200
coolermaster MWE gold 650W fully modular
old HP hard drive (not sure what the exact model is)
m.2 SSD from my old laptop
wd green 120
the pc is an upgrade over my old pc which just stopped working, i made a post on it some time previously on the forums. the upgrades were
ryzen 5 1400 --> ryzen 5 5600x
asrock AB350M --> msi b550 a pro
everything else remained the same
Edit:
Hey guys thanks for your help, I ended sending this into someone because after asking around on some other forums I couldn't figure it out. Turns out my power supply was shot and is unstable for some reason. I'm going to issue an RMA now and try get this all fixed. Thanks again for your help
