I'm having a problem with RGB on my ASUS MAXIMUS IX EXTREME motherboard.
When a system is off, my rgb lighting is normally working, but when i press power button, about a half of a second later all rgb turns off.
In BIOS i have RGB lighting turned on, and in sleep, hibernate too.
I've tried, different OS's, unplugging disks and all PCI-E cards, resetting BIOS but nothing helped.
Any help?
https://linustechtips.com/topic/1379460-problem-with-rgb/
Any help?
Do you have any programs to control your rgb like Armoury Crate from Asus or ICue from Corsair? If not try to install Armoury Crate and check all compatible devices. Also which rgb do you have, only the motherboard or also argb devices?
https://linustechtips.com/topic/1379460-problem-with-rgb/#findComment-15034990
on windows I have used Asus Aura and on Linux OpenRGB.
I don't think that's a software issue, because the rgb turn off, before system starts to boot. I have also disconnected all my drives, but the rgb still lights off after starting the system.
I'm only using the motherboard rgb.
https://linustechtips.com/topic/1379460-problem-with-rgb/#findComment-15035087
