Soo... i was playina a game (nothing new ther) and i did not notise that it started rainig outside... and i had my window open, and it started filling with water util it twisted inwards, where it emptied everything all over my room, including my stasionary pc... so my question is, wath can i use to "force" the water out of all my components? Electrical spray? Alcohol? Anythig helps. thx for any help.
https://linustechtips.com/topic/1379335-water/
Remove all the components, and leave them out to dry somewhere warm and dry for 2-3 days.
You might be screwed since it was on when it died, which may have caused a short but its worth a shot.
https://linustechtips.com/topic/1379335-water/#findComment-15034216
