CPU Cooler Height
Go to solution Solved by Dogzilla07,
It's gonna fit np, there's at least 2-3 mm of overhead between what a case manufactures puts on specs and a cooler manufacturer puts on specs. And while there may exceptions, being 0.6mm under will always fit.
Heck the Dark Rock Pro 4 fits and this bigger dual tower is 163mm officially
https://photos.google.com/share/AF1QipPZBDiOrIQNtdv79yF-m_GmIzUP8GAoB9ciVHyTchlCcfj_hy-uZnD7Dr-pD8HvIw?pli=1&key=dnhxMU9oUnVJUEw0R2pmeE5Ec1RpQ0E1V2NzTFF3
Hi everybody,
I'm rebuilding my system into my old Corsair iCUE 220T RGB, and it has a cooler height limit of 160mm. I am looking at getting a bequiet Dark Rock 4, which has a height of 159.4mm (taken from their website).
I am just wondering is this too close to fit as I am not sure if this limit conforms to all motherboards?
Thanks
https://linustechtips.com/topic/1376783-cpu-cooler-height/
https://linustechtips.com/topic/1376783-cpu-cooler-height/#findComment-15016237
great, i shall purchase and cross my fingers. thanks for your help
https://linustechtips.com/topic/1376783-cpu-cooler-height/#findComment-15016407
