15 minutes ago, LouieJustin907 said:
I have these weird like scan lines on my computer very noticable when I use display port but when I plug in HDMI it seems to go away but I can still see em any help would be nice
Are you sure the DP cable was plugged in all the way? It could take quite a bit of force to fully engage the locking mechanism. Have you also tried another cable to rule out an issue the cable?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
Yes I'm sure it was plugged in all the way. I've tried 3 different dp cables with same result horizontal scan lines
7 minutes ago, LouieJustin907 said:
I have a rtx 3080ti FE and a Samsung Odyssey g7. Looking up the issue on Google it seems that it's kind of a common issue I guess I'll try contact Samsung soon
Yea if both products are still under warranty, give them a hard time about it!
