So I have a PC which was built for gaming but I now also use for work, not really a problem but the CPU does tend to Overheat. I am looking to get a New CPU cooler but the Front panel on the Case does seem quite limiting it does have gaps at the top and bottom but quite far away from the fans really. However I have recently seen you can get a mesh panel for the P300, has anyone know if this will help overall case airflow (I have max fans in the case) 2 140M pulling in from the front.
Thanks
https://linustechtips.com/topic/1374656-phanteks-p300-front-panel/
