Help with my upgrades
2 hours ago, raccattack said:
Alright, I have a HP Pavilion - TP01-1105t and I’ve been wanting to upgrade it with a new psu and gpu.
This prebuilt only has 150 watts since it has intergraded graphics (intel UHD 630)
I want to upgrade the psu to 400 watts but it’s non upgradable with EVGA or any other kind of psu, it’s a certain kind of HP power supply. I know that I can add the 1050 Ti which is the gpu I wanna add.
if you have any suggestions or help I’ll take it.
I would also like some motherboard suggestions for a intel i3 10100 because i plan on making something better eventually.
thanks. I’m on a very tight budget
I do think it is possible to either upgrade the PSU for another HP unit or a whole different PSU, if you go regular brand for a PSU then I would suggest finding one that is small enough and has an adapter for the power connectors on the Motherboard. I could not find an adapter for that model but I have seen them before.
As for a new PC entirely I have made 2 lists, one Intel and one AMD below, they are the same except the CPU & MB...
CPU: Intel Core i3-10100F 3.6 GHz Quad-Core Processor ($98.80 @ Amazon)
Motherboard: Gigabyte B560M DS3H Micro ATX LGA1200 Motherboard ($94.99 @ Amazon)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory ($64.98 @ Amazon)
Storage: Seagate BarraCuda Q5 500 GB M.2-2280 NVME Solid State Drive ($62.99 @ Amazon)
Video Card: MSI GeForce GTX 1050 Ti 4 GB Video Card ($291.00 @ Amazon)
Case: Cooler Master MasterBox NR400 (w/o ODD) MicroATX Mid Tower Case ($69.36 @ Amazon)
Power Supply: EVGA SuperNOVA GA 550 W 80+ Gold Certified Fully Modular ATX Power Supply ($54.99 @ Amazon)
Custom: RGB Case Fans 3 Pack, GIM 120mm Chassis Fans (366 Modes with Controller and Remote) PC Computer LED Fan, Reinforced Quiet Fan Blade Design, Adjustable Colorful Cooling Cooler ($21.99 @ Amazon)
Total: $759.10
CPU: AMD Ryzen 5 1600 (12nm) 3.2 GHz 6-Core Processor ($150.99 @ Amazon)
Motherboard: Gigabyte B450M DS3H Micro ATX AM4 Motherboard ($80.68 @ Amazon)
Total: $796.98
