So I've been planning on building my own pc, but I have no idea what motherboard would be good. I don't trust some forum pages so I came here because everyone here knows what they're talking about. I need recommendations for a motherboard that would best suit my build which has an AMD Ryzen 7 5800x, a water cooling compatible 3070, Corsair Vengeance 32gb, with two Samsung NVMe's, and again, this build will be watercooled. Thanks :).
https://linustechtips.com/topic/1373887-help/
44 minutes ago, martianman95 said:
AMD Ryzen 7 5800x
Which size do you want? Or which case do you want?
Mini-ITX? Micro-ATX? ATX? E-ATX?
Micro-ATX should be the cheapest because they are sold the most.
Do you want RGB?
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
https://linustechtips.com/topic/1373887-help/#findComment-14995153
Do you want RGB?
I forgot to mention that, but yes, I do want rgb, and I want an ATX motherboard and I'm willing to risk longer wait times for a part. The case I want is a Corsair 7000x, which should be big enough for an ATX motherboard
https://linustechtips.com/topic/1373887-help/#findComment-14995174
1 hour ago, martianman95 said:
AMD Ryzen 7 5800x
I would go for the Gigabyte B550 Aorus Elite V2.
It's an ATX mainboard whose VRMs can deliver 100 A, which is enough to max out your 5800X.
It has a S/PDIF (TOSLINK) audio output, so you can easiely connect a 5.1 or 7.1 AV receiver.
Also it has a nice backside, so you don't need an I/O cover.
It has 2 M.2 slots.
And it supports RGB.
In germany it's 117 € = 138 USD.
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
https://linustechtips.com/topic/1373887-help/#findComment-14995178
