Post memes
Go to solution Solved by Skiiwee29,
<-- Thread Locked -->
While this is off topic.. its still meant for meaningful conversation that doesn't fit any of the other areas of the forum. Meme dumping and shitposting is NOT one of these.
                         Dream build:
Intel Core i5-10600K | GIGABYTE Z490 AORUS ELITE | Cooler Master MasterLiquid ML240L| RGB Corsair Vengeance RGB Pro  16GB (2x8) CL18 3600MHz |
Intel 660P 512GB NVMe | Kingston A400 SSDNow 480GB 2.5" | WD "Caviar" Blue 1TB 7200RPM 3.5" | MSI GeForce RTX 2060 Super Gaming EVGA SuperNOVA 750 G+ | THERMALTAKE RGB H200 USB 3.0 |
Peripherals:
Keyboard: Corsair K65 RGB Rapidfire
Mouse: Corsair Harpoon RGB Pro
Monitors:
(1) LG 27'" 27Gl650F-B 144hz 1ms IPS G-Sync Pivot 3
(2) Acer Predator XB241YUbmiprz 23.8" 144Hz 1ms G-Sync
Headset:
Kingston HyperX HX-HSCSC2-BK-WW Cloud Stinger Core
https://linustechtips.com/topic/1373504-post-memes/
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1373504-post-memes/#findComment-14992190
Guest
