I fixed my gpu crashing issues by underclocking it in msi afterburner but it came back for me again.
according to reliability history:
A problem with your hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name:    LiveKernelEvent
Code:    141
Parameter 1:    ffffe40b7538d460
Parameter 2:    fffff8005d86dac0
Parameter 3:    0
Parameter 4:    22cc
OS version:    10_0_19042
Service Pack:    0_0
Product:    256_1
OS Version:    10.0.19042.2.0.0.256.48
Locale ID:    13321
Extra information about the problem
Bucket ID:    LKD_0x141_Tdr:6_IMAGE_amdkmdag.sys
Server information:    d97c3b5a-7185-4bf1-aac1-0a7718526a41
heres from event viewer:
Device PCI\VEN_1002&DEV_731F&SUBSYS_E4111DA2&REV_CA\6&12d3302e&0&00000019 had a problem starting.
Driver Name: oem12.inf
Class Guid: {4d36e968-e325-11ce-bfc1-08002be10318}
Service: amdkmdag
Lower Filters:
Upper Filters:
Problem: 0x0
Problem Status: 0xC00000E5
Also my gpu driver is from 03-10-21 withoutt the software since it was the stable one i got
ram is hyperx 3200 and is on qvls list, bios mobo is updated to latest. Also pcie cable is a daisy chain.
I can't rma right now because of school so any help other than suggesting me to rma it would be appreciated
Thank you.
https://linustechtips.com/topic/1372899-5600xt-still-crashing/
2 minutes ago, evilcloud said:
psu should be ok.
just came across this - https://community.amd.com/t5/drivers-software/bsod-amdkmdag-sys/td-p/453866 are you running afterburner?  Might be an idea to uninstall it, see if it fixes the issue
when i dont run afterburner i see flcikering in my screen like tv noise??
I feel like my card is ocing too much for some reason.
https://linustechtips.com/topic/1372899-5600xt-still-crashing/#findComment-14987714
If you have to undervolt your graphics card to make it stable (not crashing), then - IMO - there's a problem with the card itself on a hardware level. I would RMA.
Maybe just try to undervolt it even futher. How far have you undervolted it currently?
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
https://linustechtips.com/topic/1372899-5600xt-still-crashing/#findComment-14987720
so far core clock is capped to 1600mhz
I dont really want to rma yet because I cant use my pc for school...
https://linustechtips.com/topic/1372899-5600xt-still-crashing/#findComment-14987733
10 minutes ago, evilcloud said:
try uninstalling any overclocking software and remove any kind of overclocking and underclocking you may have in the bios - revert to defaults, see if if you get any problems, then take it from there.
how to check if theres any kind of over/under clocking in my bios, but so far the one thing I did was enable xmp only
https://linustechtips.com/topic/1372899-5600xt-still-crashing/#findComment-14987736
It's a shitty situation for sure man, I'm sorry.
Does the "TV noise" disappear if you undervolt it further?
GAMER
Home LAB
Racing SIM
https://linustechtips.com/topic/1372899-5600xt-still-crashing/#findComment-14987737
XMP only? Intel chip? iGPU?
Is the 5600XT important for a specific program?
GAMER
Home LAB
Racing SIM
https://linustechtips.com/topic/1372899-5600xt-still-crashing/#findComment-14987739
Thank you for the consolation , I appreciate it.
The tv noise disappeared when I truned on the msi afterburner.
https://linustechtips.com/topic/1372899-5600xt-still-crashing/#findComment-14987741
Just to be exact, is it when you apply the undervolt profile, that the noise goes away?
GAMER
Home LAB
Racing SIM
https://linustechtips.com/topic/1372899-5600xt-still-crashing/#findComment-14987743
i have 5600x amd cpu
No, its just my gpu I don't mine.
Ah right, no iGPU then.
Well, you can't use your PC without the GPU anyways so yeah RMA'ing would make your PC unusable.
GAMER
Home LAB
Racing SIM
https://linustechtips.com/topic/1372899-5600xt-still-crashing/#findComment-14987751
2 minutes ago, experiencednoob said:
yes
Have you only tweaked the voltage curve or have you also underclocked the memory?
GAMER
Home LAB
Racing SIM
https://linustechtips.com/topic/1372899-5600xt-still-crashing/#findComment-14987752
5 minutes ago, experiencednoob said:
just directly inputted 1600
What happens if you reset the Core Clock and then after turning down the Memory Clock? Does the noise go away?
GAMER
Home LAB
Racing SIM
https://linustechtips.com/topic/1372899-5600xt-still-crashing/#findComment-14987779
3 minutes ago, experiencednoob said:
if i reset core clock the noise returns and i cant change the memoryclock
Oh okay, fair enough...
Maybe try to tweak the voltage curve - a proper undervolt. Maybe it will give you a better result than setting a 1600MHz Core Clock.
GAMER
Home LAB
Racing SIM
https://linustechtips.com/topic/1372899-5600xt-still-crashing/#findComment-14987800
yeah i dont know the curve editor only has like 3 points to move and also I recently tried updating the driver to 21.9.1 didn't work and tried to msi afterburner an dit worked for a couple of seconds then crashed. Now i just installed the driver directly w/o the software and underclock it in msi again
even viewer shows:
Service: amdwddmg
Lower Filters:
Upper Filters:
Problem: 0x0
Problem signature
Code:    141
Parameter 1:    ffffb4083113b460
Parameter 2:    fffff8018e56dac0
Parameter 3:    0
Parameter 4:    5344
Service Pack:    0_0
Product:    256_1
Locale ID:    13321
Server information:    a44725de-2675-4a21-8bae-d8923314430d
https://linustechtips.com/topic/1372899-5600xt-still-crashing/#findComment-14989423
