Budget (including currency): 2000$ CAD (Canadian Dollar)
Country: Canada
What will it be used for: Editing, Gaming, School.
Main Details:
Pc Part Picker List: https://ca.pcpartpicker.com/list/NgP7K3
In terms of what res, I just want to play at like 1080p or 1440p.
What do you think? Also if you can please recommend me things.
https://linustechtips.com/topic/1371584-my-first-pc-build/
Ill assume youll do editing at that res as well.
PCPartPicker Part List
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($356.75 @ shopRBC)
CPU Cooler: Noctua NH-U12S redux 70.75 CFM CPU Cooler  ($62.95 @ Amazon Canada)
Motherboard: MSI B550M PRO-VDH WIFI Micro ATX AM4 Motherboard  ($115.50 @ Vuugo)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($94.99 @ Memory Express)
Storage: Western Digital Blue 1 TB 2.5" Solid State Drive  ($99.99 @ Amazon Canada)
Storage: Western Digital Blue 2 TB 3.5" 5400RPM Internal Hard Drive  ($54.99 @ Amazon Canada)
Video Card: NVIDIA GeForce RTX 3080 10 GB Founders Edition Video Card  ($1029.99 @ Best Buy Canada)
Case: Cooler Master MasterBox NR400 (w/ODD) MicroATX Mid Tower Case  ($64.98 @ Amazon Canada)
Power Supply: MSI MPG A-GF 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.99 @ Amazon Canada)
Total: $2000.13
Generated by PCPartPicker 2021-09-08 01:45 EDT-0400
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1371584-my-first-pc-build/#findComment-14977888
Please do me a favor and don't build aircooled system in that case 🥺🥺🥺🥺🥺🥺
Also, You should not buy WD SN550
Here's list of some cheap but good drives https://ca.pcpartpicker.com/user/Dr0idGh0sT/saved/#view=Vx6Jyc
And here is list for you to build you PC in O11 😄
https://ca.pcpartpicker.com/list/HVgCNP
Of course you can build aircooled PC in that case if you wanted to, But whyyy? 😄 😄 😄
Here is second list
https://ca.pcpartpicker.com/list/cBY2Xb
https://linustechtips.com/topic/1371584-my-first-pc-build/#findComment-14977992
