In general, you would need an 8 pin EPS for CPU power a 24 pin for Motherboard power and 2 8 pin for your PCIE/GPU Power. Your board does have a 2 4 pin EPS so you could get one as well if you wanted, but its not 100% necessary under 99% of use case scenarios.
Any other cables are not really necessary unless you want them to be uniform even though no one will see anything other than the ones listed.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1370679-cablemod-help/#findComment-14971652
Okay, this clears things up. Thank you!
https://linustechtips.com/topic/1370679-cablemod-help/#findComment-14971738
Also, are these all EPS cables? And what about SATA?
https://linustechtips.com/topic/1370679-cablemod-help/#findComment-14971760
