Hi everyone. So I figured out my previous gpu problem but I'm still having some weird issues. I have a Radeon 7990 that when I first installed it, I had 3x1 Eyefinity  and I was trying to get a 4th display working but kept getting an error when saving the resolution. I decided I'd rather use my higher resolution monitor than the 3 way eyefinity so I disconnected 2 of the Samsung displays. Well this morning I decided I wanted my eyefinity back so I disconnected the 24in monitor and hooked all 3 samsung displays back up. Now I can only get two of them to work where I had 3 working previously through the same connections.
The only thing I can think of is that I need active adapters for anymore than 2 monitors. What bothers me is that they worked fine the way I have it connected now. I've done just about everything I can think of to try and fix this problem but nothings working. I've tried all different outputs on the 7990. I've tried different hdmi cables, displayport to hdmi adapters and even dvi to hdmi adapters. I deleted the samsung registry keys. I deleted the catalyst drivers and removed all AMD software with their removal tool (which I just found today, pretty nifty). I am pretty much grasping at straws here. I have an active displayport to hdmi adapter, but the 7990 only has mini dp or dvi. I ordered a mini dp to regular DP adapter so I can use my active DP adapter and I'll report back on thursday when that arrives.
Part of me is wanting to just format and start from scratch to see if the displays will work again, but I've done that so many times this week that I just am tired of re-installing skype and chrome and all that crap.
Can anyone confirm that I would need active adapters over mini dp passive adapters? Why would it work before and not now?
https://linustechtips.com/topic/137010-eyefinity-and-active-vs-passive-adapters/
Yep, I believe you're gonna need an active mini-DP to HDMI/DVI adapter for it to work in EF mode. I had a 3 way HD7970 setup before going two way R9 290X, with the HD7970's I had to used an active mini-DP to DVI (I prefer DVI) adapter for the 3rd monitor to work. I'm not sure about the R9 280 series and below, but with the R9 290/290X, there's no need for an active mini-DP, I'm actually using two DVI and one HDMI ports for my monitors.
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
