Problem with aio
Go to solution Solved by Mrlolimaster,
53 minutes ago, TeraBitz said:
The fans on your radiator look very bulky and tall and this could be causing the problem. Your options would be to move your radiator to the front of the case or change the fans on your radiator. But your best would to be to move it to the front of your case.
Fans are all standard it wasn't the problem, I discovered the problem was the height of the rams
Ok so I got a coolermaster mb511 argb mid tower case with Asus tuf gaming b560m-e motherboard I installed in the motherboard and everything and when I try to put in top 240ml radiator the fans are pressing on the ram sticks and I can't put it in (I did check the clearance and there should be enough space) am I doing something wrong here ?
https://linustechtips.com/topic/1369951-problem-with-aio/
https://linustechtips.com/topic/1369951-problem-with-aio/#findComment-14966535
https://linustechtips.com/topic/1369951-problem-with-aio/#findComment-14966695
