Hello all,
I recently upgraded my pc from a 3rd gen i5 to a 10th gen i5 10400f, It is currently running on a Gigabyte H410MH V2 motherboard with 8gigs of ram and a 1050ti Gpu,
Sometimes when i turn on my pc, the gpu fans wont spin and no signal is outputted, I know that the pc booted correctly because the num lock key etc lights up.
i tried with a different gpu (gt1030), the system works just fine, i installed the 1050ti on a different pc it worked fine there..
so my issue is this
sometimes the 1050ti wont work and the fans wont even spin, if i remove that  card install another one (1030) turn the pc on run it for a couple of minutes , shut it down remove the 1030 and  re install 1050ti
the card works fine like nothing ever happend. (this has happened at least half a dozen times  ) i dont know whether this is a problem with my gpu or the motherboard
if any one else faced a similar issue please share your thoughts and kindly help.
https://linustechtips.com/topic/1369044-weird-issue-with-my-gpu/
Makes me wonder if it might be a driver issue.
