Side components
Solved by Hairless Monkey,
You can install a PCIe to M.2 adapter in your motherboard in the second PCIe X16 slot, and you will be able to use both drives.
However, that second PCIe X16 slot on your motherboard runs at PCIe 2.0 X4. You would need at least a PCIe 3.0 X4 slot to get the full performance from a PCIe 3.0 NVME drive. The result is that you will get about half of the rated speed of the drive. It will still be faster than a SATA SSD, so this may be acceptable to you.
