Budget (including currency): None
Country: USA
Games, programs or workloads that it will be used for:
Let's assume I am looking to get a 3080ti eventually. I am looking to get a riser cable to show it off better in my case. Do I need one that is PCI-e 3.0 or 4.0? and does it matter?
Use this card as reference: https://www.newegg.com/msi-geforce-rtx-3080-ti-rtx-3080-ti-ventus-3x-12g-oc/p/N82E16814137651
Paired with this riser cable: https://www.newegg.com/p/N82E16812229002?Item=N82E16812229002
Using it in this case: H500p Mesh: https://www.newegg.com/gun-metal-cooler-master-mastercase-h500p-mesh-atx-mid-tower/p/N82E16811119353?Description=h500p&cm_re=h500p-_-11-119-353-_-Product&quicklink=true
Any recommendations for riser cables would be amazing! Help me out please!
https://linustechtips.com/topic/1368174-what-riser-cable-do-i-need/
So if you want to get a PCIe Gen4 Card, then you need a Gen4 cable. Thats unfortunately how it is, even if the data rate would not even saturate only PCIe Gen3.
But if you want to insert a Gen3 card first, I actually don't know if you'll be good with the Gen4 cable or if you may need an older Gen3 cable.
LINKUP - Ultra PCIe 4.0 X16 Riser-Kabel Geschirmte Vertikale Gaming-PCI-Express-Gen4-Montage┃Universal 90-Grad-Buchse {20cm} 3.0 Gen3-Kompatibel: Amazon.de: Computer & Zubehör
This one sounds solid, but if you only need 20cm, you can save a few bucks. Check out a few reviews.
Does your motherboard have PCI Express gen 4? If not, then there's no point getting a gen 4 riser cable, you will just pay extra.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
Yup! The one I'm getting is Gen 4, thank you!
Thanks! I'll be getting this one I believe! I need the 90 degree
https://www.newegg.com/p/1W7-00BS-00015?Item=9SIAFSTD028881
