SPECS:
CPU: i7 7700
GPU: GIGABYTE G1 GTX 1060 6GB
MOBO: ASUS STRIX B250F
RAM: KINGSTON 8x2 GB 2400mhz
PSU: COUGAR 550W
Okay so basically this is what happens:
1-I boot from the iGPU while the GPU is plugged in → I get a blue screen if I do anything NVIDIA GPU related (i.e install the NVIDIA drivers) and GPU fans go wild.
2-I boot from the GPU but I get a black screen → my windows get corrupted (sometimes) and I have to get back to a restore point (with the iGPU) but sometimes it is just a usual ordinary black screen (https://streamable.com/ilfhov).
3-I boot from the GPU and there is no black screen → everything is as smooth as butter, games running fine, windows running fine.
4-I boot from the iGPU alone → buttery smooth also (in fact i am writing this post from my computer while using the iGPU).
NOTE: if I want the GPU to boot normally I usually have to reseat the GPU, change the PCI-E slot, and pray that it boots normally.
(i couldn't exactly know were the problem is due to how unstable the GPU is, it works sometimes it doesn't in others)
All that started happening after the shipment of this computer, before that it was working perfectly.
The computer was super dusty cleaned it (get's dusty super fast thought T_T) didn't change anything, tried changing some settings in the bios, removing the CMOS battery all this jazz nothing worked.
I'm betting it's a hardware issue but is there a way to confirm that it's either the GPU or the (PSU/MOBO) fault (might be software issues also idk).
Any suggestions for where the problem could be or what I should be doing to fix it?
Thanks in advance.
https://linustechtips.com/topic/1367744-unusual-problems-with-my-gpu-help/
