7 minutes ago, Entonite said:
Can I swap the cables around and use the non daisychain ends on the gpu, and the D.C. ends in the psu ?
Why do you want to plug your cables in backwards?
https://linustechtips.com/topic/1366201-pcie-cable-question/#findComment-14939258
41 minutes ago, Entonite said:
Well they fit.
You followed the pinout diagrams to ensure all the right voltage pins are in the right place?
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1366201-pcie-cable-question/#findComment-14939401
2 minutes ago, Entonite said:
Not turning it on like this , don't have the cpu either. But they just match up.
Match up according to what? There is Ground, 12v+, Sense A and Sense B pins in there, if they're in the wrong places you're going to severely damage something. You're taking a lot of risks without any proper research for aesthetics.
https://linustechtips.com/topic/1366201-pcie-cable-question/#findComment-14939430
Why do you think I'm asking ?
And the the cables with the Normal 6+2 side by side go into both the same way. Nothing forced nothing cut , as if they were ment to be there without the daisychain
https://linustechtips.com/topic/1366201-pcie-cable-question/#findComment-14939438
13 minutes ago, Entonite said:
It's just a ROG Strix 850w
I know. Must be a to expensive variant of that unit which is a to expensive variant of the Seasonic Focus.So it's a to expensive of a to expensive unit. Is it working well like you connected in the last picture?
https://linustechtips.com/topic/1366201-pcie-cable-question/#findComment-14939525
No CPU yet. No power running . It's why I'm asking if I can do what I want
https://linustechtips.com/topic/1366201-pcie-cable-question/#findComment-14939562
