Hey guys,
I hope everyone is keeping well and my apologies if I've placed this into the incorrect thread.
Quick question, I've an older HP 2810-23G J9021A switch in my home network cabinet. However, the fans are quite noisy so installed a couple of resisters on the switches fan headers.
My question and idea is, would I be able to install an internal toggle switch to the switches internal fan circuit, that would allow me to switch between "full speed" and "half speed"? I was simply going to cut the fans cable, connecting the 12v lead to pin 1 on the toggle switch, with outputs; pin 2 12v to 12v (full speed) & pin 3 12v to a resistor cable (half speed). While leaving both the GND & yellow signal cable the same.
I just don't know how the switch would react with the added switch or if their might be any negative effects?
Many thanks in advance!
https://linustechtips.com/topic/1365447-modding-switch-fans/
35 minutes ago, new11 said:
Hey guys,
Sounds like an “is there room” issue with the internal requirement.
https://linustechtips.com/topic/1365447-modding-switch-fans/#findComment-14933950
