Hello all,
I have 100 dollar budget to spend upgrading cooling (small gift). My current set up is an ATX tower with three 120mm fans in the front (as intake), 1 120 mm in the back (exhaust) and the one that comes with the air cooler.
Honestly I am pretty happy with my current temps (low 40s at IDLE and low 70s at full load), I am running on an AMD 5600X. But since I have that extra money I thought on 'upgrading' for aesthetics/ a little gain in temps (?) and my options are:
1) AIO: MSI MAG Coreliquid 240R liquid CPU cooler (https://www.newegg.com/msi-liquid-cooling-system/p/N82E16835846008?item=N82E16835846008&source=region&nm_mc=knc-googleadwords-pc&cm_mmc=knc-googleadwords-pc-_-pla-_-liquid+%2f+water+cooling-_-N82E16835846008&gclid=CjwKCAjw092IBhAwEiwAxR1lRumbj4D40OW-UQWv3zGth39qjAo0FiV2cBK2Dtq6DwwCJqsCY-YA3RoC4P4QAvD_BwE&gclsrc=aw.ds
With this solution I would get rid of my current cooling tower... of course
2) Lian li Unifan SL120 RGB (https://www.newegg.com/lian-li-uf-sl120-3b-case-fan/p/1YF-005G-00015)
With this option I would replace the exhaust fan and I would add two exhaust fans at the top. My expectation is that both solutions would keep about the same temps but maybe option two can improve cooling to the rest of the components since it is exhausting heat from the whole case?
What are your thoughts?
Thank you!
https://linustechtips.com/topic/1365190-aio-vs-air-cooling/
<-- Moved to Cooling -->
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1365190-aio-vs-air-cooling/#findComment-14932331
A 240mm rad is about equivalent to an nh-d15 in performance, so option one would be the most cooling for your cpu.
And with all the fans you already have, your other components aren't going to get much better cooled unless you stick heat sinks to stuff, but even then more/different fans won't matter (functionally at least, visuals and noise are the areas changing fans will matter)
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/1365190-aio-vs-air-cooling/#findComment-14932343
Depending on the air cooler you currently have, that 240mm AIO may not even be much of an upgrade cooling-wise. You really need 280mm or better before you start beating what an air cooler can achieve. It would mostly be about the "looks".
Also, bear in mind, that while AIO failures are pretty rare (at least on decent AIOs), they can still happen. It's always a calculated risk, and personally, I wouldn't take it if you're already doing fine with an air cooler.
The 120mm AIO would be completely useless. Don't even bother with that. Despite what air cooler you have currently, you're better off with that an a 120mm.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1365190-aio-vs-air-cooling/#findComment-14932366
120 and 140 rad ones have no place in ATX or micro ATX cases. They dont perform well with all the drawbacks of going liquid
Desktop benching:
https://linustechtips.com/topic/1365190-aio-vs-air-cooling/#findComment-14932367
@Chris PrattOP linked 240mm aio and a 3 pack of 120mm fans.
desktop
HTPC
https://linustechtips.com/topic/1365190-aio-vs-air-cooling/#findComment-14932409
