Acer identification problem
Solved by Tegneren,
The G-sync compatibility list is mostly BS anyways. They have som arbitrary requirements like that freesync has to be activated on the monitor out of the box.
You can activate G-sync on all freesync monitors and it works just fine. (as long as you have a gtx1000 series or newer gpu)
Ishikudeska ·
Xxu ·
Posted in Servers, NAS, and Home Lab0 -
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
play_circle_filled
Latest From ShortCircuit:
