Is there a Dual Monitor KVM Extender that will go through 1 CAT5 port?
Hi There,
With working remote for the last year, I've set up my computer to live in the living room for gaming, and KVM a single monitor over to the office.
Since it looks like remote work might be a long time thing, I'm looking to upgrade up to a dual monitor set up.  The issue I'm running into is that the only Dual-monitor KVMs I have found rely on two CAT cables like this:
https://www.alibaba.com/product-detail/IPHE2-120UA-Dual-Monitor-Extended-Display_62432299725.html?spm=a2700.galleryofferlist.normal_offer.d_image.74f3287eEzV1tf
TLDR, is having two monitors going through a single CAT5 port a pipe dream, or is there something I could manage without having to run extra cables through the wall?
I only need 1920 x 1080 with 60 or 30hz per monitor, could possible drop to VGA or DVI as well to manage.
Cheers!
37 minutes ago, Yoshilovescookies said:
Hi There,
Cheers!
Going analog would be worse not better.  Lately when I drill holes for cables I’ve taken to putting in smurf tube instead of fishing cables directly because everything gets updated and cables don’t pull well.
